постоянно перегорает предохранитель №18
Сообщений в теме: 12
#1 ОФФЛАЙН   Fil
Fil
  • Cообщений: 3776
Отправлено 03 August 2009 - 11:17
Это предохранитель, который отвечает за прикуриватель....
Что может замыкать? Никто не сталкивался?
C126 420SEC '86
W123 300TD Turbodiesel '82
W123 300D '83 - продан
#2 ОФФЛАЙН   Fil
Fil
  • Cообщений: 3776
Отправлено 06 August 2009 - 10:40
Как обычно, меня не может не радовать изобилие ответов... :-?
C126 420SEC '86
#3 ОФФЛАЙН   ЗоМер
Отправлено 06 August 2009 - 10:54
Вот список предов с MB клуба :
Список предохранителей. W126 280SE
Первая сторона
b(16A) (power windows front left, rear right)
2(8A) high beam right, high beam indicator
4(8A) high beam left
6(8A) low beam right
8(8A) low beam left
10(8A) control unit/water pump/heating water valve for
autom.heater/climate control system, back-up lamp,
carburetor heater, idle cut-off valves, (automatic
transmission, relay auxiliary fan term.86)
12(8A) stop-turn signal lamp, instrument cluster,
(cruise control, leveling system indicator lamp,
tachometer)
14(25A) heater rear window, horn, (seat heatig rear, fanfares)
16(16A) (sliding roof, adjustable seat rear)
d(25A) (adjustable seat front left)
Вторая сторона
a(16/25A) (power window front right, rear left,
adjustable seat front right)
1(8A) parking/tail light right, warning buzzer,
license plate/instrument/hazard warning
switch/heater and ventilation controls/
rocker switches illumination, (electronic radio
illumination, head lamp cleaning unit)
3(8A) parking/tail light left
5(8A) fog light, rear fog light
7(16A) windshieldwiper and washer, optical horn,
(outside mirror, relay I power windows term.87a)
9(8/16A) cigar lighter, glove compartment light (radio,
seat heating front, heating system for washer
jets, cigar lighter rear)
11(25A) blower motor (air condition compressor,
switch-over valve idle stabilization)
13(8A) diagnostic, hazard warning system, clock,
(central locking system, electronic radio)
15(8A) trunk light, roof light front and rear,
illuminated vanity mirror, (door lights,
automatic antenna, relay II power windows term.86+87)
c(16/25A) (auxiliary fan, auxiliary heating)
Цепи, показанные в скобках, являются опционными и могут отсутствовать на Вашей машине.
Что-то нет там 18 номера. А сам прикуриватель у тебя не замыкает ?
#4 ОФФЛАЙН   Fil
Fil
  • Cообщений: 3776
Отправлено 06 August 2009 - 14:21
Ну прикуриватель то вообще я вынял... но всё равно пред горит
C126 420SEC '86
#5 ОФФЛАЙН   ЗоМер
Отправлено 06 August 2009 - 14:23
Точно 18 ?
#6 ОФФЛАЙН   Vano116
Vano116
  • Cообщений: 122
Отправлено 06 August 2009 - 14:54
А по схеме больше ничего не подключено, точно? У меня на этот предохр еще и обогрев заднего стекла подключен, нак он дофига жрет, мерял, было больше 5 А.
Мерсовод со стажем.
W116 2,8 akpp зеленый крокодил - машина для души.
DODGE-CRYSLER - miniven - рабочая лошадка
#7 ОФФЛАЙН   Fil
Fil
  • Cообщений: 3776
Отправлено 06 August 2009 - 20:59
А как это на предохранитель 8 ампер подлючено заднее стекло???
Точно 18-й!!!
C126 420SEC '86
#8 ОФФЛАЙН   Vano116
Vano116
  • Cообщений: 122
Отправлено 07 August 2009 - 07:44
Точно 18-й!!!
У меня 116, а не 123, поэтому нумерация другая, но по схеме так.
Мерсовод со стажем.
#9 ОФФЛАЙН   Fil
Fil
  • Cообщений: 3776
Отправлено 07 August 2009 - 09:17
А я вообще-то, веду речь о 126-ом купэ :neutral:
C126 420SEC '86
#10 ОФФЛАЙН   Dim W126
Dim W126
  • Cообщений: 593
Отправлено 07 August 2009 - 09:27
некоторые цепляют на провода прикуривателя музыку и прочие вещи.
ex. W123 200D 1977. -с него началось знакомство с MB.
W126 300 SDL 1986. чёрный. ОМ603.960 turbo,акпп
W126 560 SE 1986.
W210 420 T-model
#11 ОФФЛАЙН   Корнелий Шнапс
Корнелий Шнапс
    Свободный художник
  • Cообщений: 3773
    заз 965
Отправлено 07 August 2009 - 09:48
+7 916 249-7О99
#12 ОФФЛАЙН   Vano116
Vano116
  • Cообщений: 122
Отправлено 07 August 2009 - 10:14
Во и получается - лампа бардачка,радио, обогрев заднего стекла - размораживатель :smile: и еще какой-то подогрев...
Мерсовод со стажем.
#13 ОФФЛАЙН   Fil
Fil
  • Cообщений: 3776
Отправлено 13 August 2009 - 12:37
Проблема решена. Банально. На плафоне освещения бардачка слетел проводок и "соединился" со вторым... :D
C126 420SEC '86
