Предохранители W123 200d,помогите перевести с английского
Сообщений в теме: 7
#1 ОФФЛАЙН   Саша 123 200д
Саша 123 200д
  • Cообщений: 897
Отправлено 08 July 2007 - 01:11
1(8A).parking / tail light right /warming buzzer / licence plate / instrument / hazard warning switch / heater and ventilation controls /(rocker switches / shift indicator electronic radio-illumination, headlamp cleaning unit
2.(8A) clock, trunc light,diagnostic,roof light front + rear,hazard warming system( electronic radio,relay 2 window lift term.86+87,autom. antenna,illuminated vanity mirror)
3.(8A)parking / tail light left
4.(8A(16A*)) cigar lighter,glove compartment light(outside mirror ,radio,seat heating front*)
5.(8A)Fog light,rear fog light
6.(16A) windshield wiper and washer,optical horn(relay headlamp cleaning unit term.86)
7.(8A) hight beam right
8.(16A(25A*)) blower motor,(climate control system * air condition compressor,switch-over valve idle stabilization,circulating pump auxilary heating / exploid engine residual heat/climate control system*)
9.(8A) hight beam left ,hight beam indicator
10.(16A(25A*)) electromagnetic clutch engine fan, heater rear window ( seat heating rear*, auxillary heating rear)
11.(8A) low beam right
12.(8A)stop lamp,turn signal lamp,instr.-cluster(relay 2 window lift term.87a,cruise control,tachometer,climate control system)
13..(8A) low beam left
14.(8A)back-up lamp,carburetor heater,idle cut-off valves,float chamber vent valve,horn,switch-over valve overload protection device,(autom. transmission `,relay auxiliary fan.term.86,control unit/heating water valve for control system,temperatur gauge outside,exploid engine residual heat term.15)
Саша 123 200д 84
#2 ОФФЛАЙН   ЗоМер
Отправлено 08 July 2007 - 01:24
Вот попробуй :D :
http://www.mbclub.ru...?idpart=2&id=75
#3 ОФФЛАЙН   Саша 123 200д
Саша 123 200д
  • Cообщений: 897
Отправлено 08 July 2007 - 07:45
Вот попробуй :D :
Некоторые пункты совпадают.Некоторые-с точностью до "наоборот".Иные-совсем не о том... :confused:
Саша 123 200д 84
#4 ОФФЛАЙН   sandy
sandy
  • Cообщений: 56
Отправлено 08 July 2007 - 08:43
Саша много переписывать - у меня есть
W123 240D
#5 ОФФЛАЙН   Саша 123 200д
Саша 123 200д
  • Cообщений: 897
Отправлено 08 July 2007 - 11:45
Думаю,было бы полезно не мне одному.Может,сделаешь услугу человечеству?
Саша 123 200д 84
#6 ОФФЛАЙН   candigger
candigger
  • Cообщений: 10
Отправлено 20 July 2007 - 12:57
переводил на коленке с твоего листа, не ручаюсь за правильность тех. терминов (некоторые -точно не понимаю, о чем речь), но посмыслу должно быть понятно
1.стояночный фонарь. задний правый габарит, предупреждающий зв. сигнал, осв. номерного знака,инструментальная панель,переключатель сигнала предупреждения о неисправности, управление отоплением и вентиляцией, указатель передачи, осв. радиоприемника, омыватель фар
2. часы,осв. багажника, диагностика, освещение салона (задн. пер.), предупреждение о неисправности, (радио, реле 2 стеклоподъемника терм. 86+87, автоантенна, осв. зеркальца на козырьке)
3. парковочный фонарь, задн. лев. габарит
4. осв. прикуривателя,осв. бардачка, зеркало заднего вида,радио, обогрев пер. сидения
5. противотуманки (пер. задн.)
6.стклоочиститель + омыватель, оптический сигнал - (видимо моргалка дальним), реле омывателя фар терм 86
7. праывй дальний
8.моторчик обдува(ситстема компрессора климатконтроля, переключатель стабилизации холостого хода, дополнительный обогрев помпы,система климатконтороля,отвод остаточного тепла двигателя (?)
9.левый дальний, указатель дальнего света
10.электроьагнитная муфта вентилятора,обгрев заднего стекла, (обогрев задн. сидений,дополнит. обогрев задней части салона)
11.правый ближний
12.стоп сигналы, поворотники, инструментальная панель (реле 2 стеклоподъемника терм.87а, крузконтрол,тахометр,система климатконтроля)
13.левы
мв 123 , 102, 200, карб.,5 ркпп,1983 г.
#7 ОФФЛАЙН   candigger
candigger
  • Cообщений: 10
Отправлено 20 July 2007 - 13:10
[[/quote]
7. праывй дальний
8.моторчик обдува(ситстема компрессора климатконтроля, переключатель стабилизации холостого хода, дополнительный обогрев помпы,система климатконтороля,использование остаточного тепла двигателя (?)
11.правый ближний
13.левый ближний
14. лампа подсветки,обогрев карбюратора, клапан отключения холостого хода (видимо автоподсоса), клапан вентиляции поплавковой камеры,звуковой сигнал,клапан переключения устройства защиты от перегрузки, (акпп - реле дополнительного вентилятора терм.86,контрольное устройство (клапансистемы контроля отопления,датчик внешней температуры,терм.15 использования остатаочного тепла двигателя)
успеха!
#8 ОФФЛАЙН   Саша 123 200д
Саша 123 200д
  • Cообщений: 897
Отправлено 20 July 2007 - 23:33
Премного благодарен!Кое-что сам разобрал,что-то вычислил по схеме или методом "тыка".Что-то остаётся непостижимым!
Итак,последняя версия:
Предохранители W123 200D 83 или 84г
1. стояночные огни справа и габаритные огни справа сзади, система очистки фар, освещение панели приборов и
печки, переключатель сигнала аварийной сигнализации , указатель передачи, осв. радиоприемника ,
освещение номерного знака.
2. часы, освещение салона и багажника, стеклоподъёмники(реле 2 стеклоподъемника терм. 86+87),
автоматическая антенна, аварийная сигнализация(?)осв. зеркальца на козырьке.
3. стояночные огни слева и габаритные огни слева сзади .
4. прикуриватель и подсветка пепельницы, освещение бардачка , зеркало заднего вида,радио, обогрев пер.
сидения
5. Передние и задние противотуманные огни.
6. дворники , омыватель ветрового стекла, оптический сигнал (видимо моргалка дальним), реле омывателя фар
терм 86
7.Дальний свет справа
8. моторчик обдува?(система компрессора климатконтроля, переключатель стабилизации холостого хода, помпа
дополнительного обогрева(?),система климатконтороля,
9.Дальний свет слева ,индикатор дальнего света.
10. электромагнитная муфта вентилятора, обогрев заднего стекла, (обогрев задн. сидений, дополнит. обогрев
11.Ближний свет справа
12. стоп сигналы, поворотники , инструментальная панель (реле 2 стеклоподъемника терм.87а, круизконтроль,
тахометр, система климатконтроля )
13.Ближний свет слева
14.Клаксон, огни заднего хода, обогрев карбюратора, клапан отключения холостого хода (видимо автоподсоса),
клапан вентиляции поплавковой камеры?,клапан переключения устройства защиты от перегрузки? (АКПП,
реле дополнительного вентилятора терм.86,контрольное устройство ?(клапан системы контроля отопления?,
датчик внешней температуры,терм.15 использования остаточного тепла двигателя?)
Может,кто поможет расшифровать белиберду п.п.8 и 14?
Саша 123 200д 84
