008 Intake air temperature sensor B17 Loose contact
009 Hot-film air mass sensor B2/5 implausibly high
010 Hot-film air mass sensor B2/5 - / / -
014 Act val potentiometer throttle valve implausibly high
016 Act val potentiometer throttle valve Loose contact
020 Idle speed control at lower control stop
022 CC, EFP actuator signals emergency mode
035 Lambda control Rich stop/mixture too lean
036 Lambda control Lean stop/mixture too rich
072 Road speed signal not recognized
107 Dwell angle control at stop of ignition output stage
111 Voltage at HFM control unit N3/4 Undervoltage
115 Voltage at HFM control unit coding bytes N3/4 implausible
Вот как-то так
